cyberleech's avatar
cyberleech
Red Light on Hub 3
I have a red light on the Hub 3, permanently on. I have attempted all the recommended remedial processes, checking connections, power on and off, it's not running too hot.
Any other remedies? New box required?
  • Tudor's avatar
    P;ease do a pin-hole reset of the hub. If the red LED persists after this the hub will need replacing.
  • Hey cyberleech, thank you for reaching out and I am so sorry to hear you are having some issues with a red light.
    Let me send you a DM and we will look into this, in the meanwhile please try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
