Rich310's avatar
Rich310
Red light on Hub 3 after pin reset
Hello,
The constant red light on my hub3 started a few months ago. I have regular intermittent connectivity and the router is starting to power cycle itself randomly.
I have performed a full reset with the pin. The router is in a cool well ventilated place and all cables are connected correctly. I have run multiple tests over multiple weeks from the myVM app.
Please could you assist me in replacing this router? The phone lines are impossible to get through no matter how many times I try and the chat bot is useless
thanks
1 Reply
  • Gareth_L's avatar
    Gareth_L
    Hello Rich310.
    Hello
    Thanks for your first post and welcome to our community.
    Sorry to hear you are having an issue with the red light on your Hub 3
    I'd like to arrange a replacement for you.
    Thanks as well for making sure the Hub is in a well ventilated place.
    If you can check your logo at the top right of your screen that would be great.
    Gareth_L
