Meg_n's avatar
Meg_n
Red light on box!
Hello
The red light is constantly on our virgin media box. We have no WiFi, which is annoying as I have to work from home. I have tried switching on and off, all cables are in place, etc. No joy. How could I arrange a technician to come out asap?
  • Tudor's avatar
    If it’s not a Hub3, where a red LED means overheating, the it means you have no broadband connection.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
  • Daniel_Et's avatar
    Daniel_Et
    Hi Meg_n 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you're having 😔
    If it's a Hub 3, please follow the below steps in the following order:
    • Turn the power switch off on the back of the Hub
    • Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
    • Use the power switch to turn the unit back on
    If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
    Thank you for your support Tudor 👍
    Regards,
    Daniel
    • Meg_n's avatar
      Meg_n
      Hey Daniel, thanks for your reply. I've tried all of these measures and the red light is still on! My internet connection has been on and off today so I don't think it's a network issue (also none reported in local area).
      How do I arrange a replacement please?
        Daniel_Et
        Hi Meg_n, thank you for your response.
        In order to discuss this with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
        Regards,
        Daniel
