Jmwhooper's avatar
Jmwhooper
Random mix of devices don't connect to internet wired or wireless
A month or 2 ago I started to see some of my devices lose internet connection, sometimes just for an hour, sometimes a few hours. It's been happening 2 or 3 times per week. The latest occurrence was on Wed this week, about 5pm and it's still happening now.
My set up is Hub 5 in modem mode with TP-link Deco mesh wifi x 3. I've tried the hub back in router mode and turned off the Deco's to eliminate that as the issue, still no luck.
Here are some of the devices being impacted:
  • I have several Amazon Alexa's, the Shows (with screens) have lost internet but are connected to the wifi, the dots are all working, the echo which is right next to the VM Hub is not working
  • My Samsung Smartthings hub is wired but has no internet
  • My LightwaveRF plus hub is wired but has no internet
  • My son's PC is wired and he has internet connection, but he can't get into the lobby on certain games he plays
  • On my mobile phone I have a wireless connection and can access most sites, but some sites are not accessible via Chrome
  • I work from home and some of my work apps are not accessible but others are
  • On my Roku stick some apps I can watch TV (iPlayer, NowTV) but others don't work (Netflix, Disney+ gives me a message about suspicious activity from my account!)
I've been on support with Virgin several times but just go around the same usual troubleshooting all of which I've done multiple times (reboot, reset etc). They haven't been able to fix it yet.
The service status for my area shows no issues, running a check on my home kit shows no issues. I have disabled the child safe and virus safe options on my account.
I'm at a loss what to do next. Yesterday for work I had to tether to my mobile all day as I couldn't use my broadband.
Is there some tech support I can escalate to above the "please can you reset the hub" script level of support? VM tried to direct me to Gadget Rescue, but it's not a device issue, it's a BB service issue.
Is it possible for certain services / devices to be blocked by VM or by the providers, but other services to work as normal?
  • UPDATE: I've set the hub back to modem mode and my Deco's are in router mode, everything seems to be working again at the moment, it's been about 45 mins since the change. I'll see how long it lasts.
    • Jmwhooper's avatar
      Jmwhooper
      UPDATE 2: Approx 1 hour after setting the hub to modem mode and everything working again, it's gone, the random selection of devices have lost connection again! So that didn't work for long.
      • John_GS's avatar
        John_GS
        Hi Jmwhooper
        Sorry to hear of any issues with the broadband.
        I can see from checking the system, you've since spoke to the team and booked a engineer visit.
        Please let us know how this visit goes.
  • legacy1's avatar
    To really test your line your mesh could be the problem connect a wire PC to the hub in modem mode then test if stable with a ping -t 194.168.4.100
  • I'm using my mesh router and the Hub 5 is in modem mode, it's the only way it will work. Using the Hub 5 as the router resulted in the intermittent connection issues again. So far it's been ok.
  • Megan_L's avatar
    Megan_L
    Hi Jmwhooper,
    Thanks for coming back to us on the Forums, we're glad your issue has now been fixed thanks to your 3rd party router.
    I have checked your services on my side just to cover all bases and thankfully there were no issues.
    However, if you do start to experience any problems with your connection again, please do reach out 🙂
    Megan
