jon1331's avatar
jon1331
Poor VPN speed
On gig1 service with hub 5 and now subbed to 4 supposedly fast vpn's (proton, surfshark, nord & express) but the best result I've had is 230mbps on surfshark. Native ISP is 1143 confirmed with samknows reslspeed. Yesterday bought TP-Link AXE75 and connected up to modem mode but only got similar or worse with all VPN on and off was down on router mode max 853. I know the 2.5 gig port has issue. I had an unmanaged switch so had connection problems. So got a managed switch coming that can disable EEE. But Ive read this still only allows gig traffic through the 2.5 gig port. Need Virgin to fix firmware. I'm still on the dodgy version :(.
Any advice on how to increase my VPN speed? Support has got me to try things but nothing has worked so far. Always 1 VPN at once and to nearest Manchester server.
Thanks in advance.
  • jon1331's avatar
    jon1331
    OK great stuff thanks. Much appreciated.
