- bk_vmediaJoining in
Are these the ranges?
ONT transmit power : -27 to -8 ( closer to zero the better)
ONT receive power : 0.5 to 5 (?)
- Matthew_ML
Hey bk_vmmedia, thank you for reaching out and we are so sorry to hear about your connection issues.
Did the above advice help?
How has it been over the weekend?
Does anyone know the reference values for ONT transmit and receive power and whether it should be higher or lower? And what these terms are actually for easy understanding?
May be it is 5x hub only then. Thanks for correcting.. Do you know the best values for those in 5x hub
- newapolloVery Insightful Person
VM's hub5 doesn't have an ONT or use the statistics you are asking about.
If you have a Full Fibre connection with VM then you will be using a hub 5x - the hub 5 and hub5x can't be interchanged.
