Callinder's avatar
Callinder
Up to speed
8 months ago
Pod use when moved to differnt home and Hub
I have two accounts with VM and used a Pod at one but decided to use an Access point instead. That property had a Hub 4 and 600 mbps broadband. Now I have the Pod but don't use it.
On my other account I have a Hub 5 and 1Gig broadband and use a Pod to extend the WiFi using an ethernet backhaul. Is there any chance of using the Pod from the home with a Hub 4 to my flat that uses a Hub 5?
  • Hi Callinder
    You'd not be able to do so as the Pod is registered to one account only and thus paired. It cannot be moved over in this scenario.
    Best wishes.
1 Reply
  • Hi Callinder
    Best wishes.
