Anikosz's avatar
Anikosz
Just joined
9 months ago
Permanent red light on router
I have tried everything but router has a constant red light and WiFi / internet terrible in the house ! But no one seems to bother .. I’m really annoyed as I know it’s faulty but customer services don’t even listen .. I done all the steps yet still permanent red light on it . Can you assist please ?
  • mrix's avatar
    mrix
    If you got a red light on your hub its likely your broadband internet connection is down in the area not just you.
  • Hi Anikosz,
    We're sorry to hear you're having an issue with your hub displaying a red light.
    We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you. They'll check the hub over and complete a replacement if needed.
    I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. Just click on the little ✉ at the top right-hand side of the page to access your inbox. 😊
    Many thanks,
    • HLucas3's avatar
      HLucas3
      Just joined
      Hi there,
      I’m having the same problem with my hub 3, have tried all the problem solving.
      help would be greatly appreciated.
      Many thanks
      • Lee_R's avatar
        Lee_R
        Hi HLucas3 thanks for posting and welcome to our community.
        Sorry to hear of the constant red light on your hub. And for any concerns this may be giving you. So that I can take a look on your behalf, I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
        Lee_R
  • Tudor's avatar
    Please do a pin-hole reset on the hub and if the red LED continues then the hub will need replacing.  VM staff member will be in touch. The WiFi signal has nothing to do with the red LED, but you need to sort that problem first.
