User666's avatar
User666
10 months ago
Packet loss
Been getting terrible packet loss mostly in evenings last 6-10h then goes away. Coincides with poor upload speed ~1mbps (normally 100mbps) and upload modulation goes to 16, so indicative of noise on line. Here is the BQM Virgin 1gig BQM
Any ideas what’s causing it? Almost like something is being switched on and off…the tines and durations do vary a bit, thought it was temperature related but think that was a red herring as issue does not revert as temperature drops in evening.
  • manytentacles's avatar
    manytentacles
    Still occuring. Every day the fix will be the next day and when that rolls around it moves to the next day. Quite honestly I don't think they intend to do anything considering it's exactly the same issue as 10 months ago when it was hot.
    I had contact from a forum VM person who said it was a fault that was due to be fixed, which was a nice break from reading on the app exactly what they sent me.
    Lies, distraction, and inaction.
      Check the power levels on the Hub during the hot periods.  The DS should be between -6 and +10 and the US between 35 to 51.  If all is okay, then as noted previously, it could be the street cabinet is overheating.
        manytentacles
        And is there even a fix for an overheating cabinet? Is that why everyone in the area is being strung along? Because obviously with temps raising year on year no one will put up with this for 3-4 months a year.
    Could be the temperature is taking the Hub’s power levels out of spec as the cable resistance changes with temperature.  Or the street cabinet is overheating?
    • User666's avatar
      User666
      They changed my hub made no difference, engineer said issue is outside my house setup.
  • Problem still persists. Everyday temperature 23-24 degrees centigrade connection will degrade in the afternoon. As we have been having some particularly warm weather for the time of year have been happing a fair bit. fault lasts 8 hours ish, Line fault is registered each time but cleared the next day as fault has vanished with the cooler temperature overnight. I have raised a new complaint; the situation is getting very tedious. I appreciate intermittent faults are trickier to resolve but losing patience.
    Yesterdays fault cleared overnight, got SMS at 11 saying fixed. Fault was back by 4pm. Engineer coming Tuesday, so maybe can diagnose issue properly, took me two hours on chat and phone to arrange.
    • User666's avatar
      User666
      Today's BQM, situation needs to be resolved, connection pretty useless when the problems kick in
      • Kath_P's avatar
        Kath_P
        Hi User666,
        Thanks for coming back and we're sorry this issue has continued. We're happy to hear that an engineer has been arranged though. They'll be able to check the hub and overall connection (internal and external) and work to get things resolved.
        Please keep us posted on how the visit goes tomorrow.
        Many thanks,
      manytentacles
      what area are you in? I had this problem last year when it was hot. they replaced the cable to my house and all that, but it persisted. The fix date kept extending but then it got colder and the issue stopped. Always about 4pm and ending at midnight.
      started happening again this Wednesday (when it got hot). You can't speak to anyone who can say what the fault is so I have no confidence that they fix it and just wait out the heat.
      terrible company but they know we're stuck as there is no competition in my area
      • User666's avatar
        User666
        St Albans, issue does not get fixed, comes back on any day temp reaches 24 C. System raises fault every time then I suspect clears itself next morning once temperatures come down. Takes out the connect from 4 ish. Not sure how to resolve intermittent issues like this
      • User666's avatar
        User666
        Yep showing local fault, but did every time before. Think by time they look at it problem is resolved and nothing to see….unless legit being fixed each time
