garypjackson's avatar
garypjackson
2 months ago
One of two ethernet PCs not showing as a connected device
Seems to be working OK but seems strange that it doesn't appear as a connected device.
I have the hub 3.0
    The Hub's Connected devices list only reports devices with a DHCP IP allocated by the VM Hub.
    Any device with a Static IP is not shown.
    Devices connected to the VM Hub via a 2nd Router or to a Wi-Fi Repeater with a DHCP server enabled will also not be shown.
    Are the two ethernet cables from the PC's directly connected to two separate ports on the the Hub 3?
