Nicholas2005's avatar
Nicholas2005
Network router hub 5 issues sometimes
Hey there I'm having issues with are houses WiFi, so ever since the new hub it doesn't do it as much.
The issue is the contant disconnections, up and down speeds and it's only when we ring em up it settles again. We also have had issues where the router restarted once and forgot itself and a new ssid for the router for some reason.
It might be the power up and down levels but it gets enough wattage and fine connection. I have checked the connections multiple times.
The issue is my mom is the WiFi holder, and she pays for it out of my money but she doesn't like the hassle of the support but for a service we pay like_70-100 for this is bad. Yes we have alot of devices but even then it should handle it in bandwidth control on the DHCP. It has happend on every hub
If a support agent sees this I'm happy to pass my mom's details or have look to send a engineer if any issues or upgrades. I am 20 but she gets the money from me for better speed because my hobby and future work is internet based as a IT network technian.
Please help
Message me for details
  • Tudor's avatar
    Please supply some stats, details below:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
  • legacy1's avatar
    You need to forget using the hub in router mode and get yourself a better router with 1Gb ports with hub in modem mode.
    This is a near duplicate of the post of 2nd Jan :
    https://community.virginmedia.com/t5/Networking-and-WiFi/Network-connection-issues-on-the-gigabit-speed-package/td-p/5605197
    If you have a service fault, your mother needs to report that to VM again, but be very specific.
    e.g. do you have a connection stability issue ( lets see the Hub's signal stats )
    or do you have a Wi-Fi coverage issue ( invest in some more Wi-Fi coverage equipment )
    What ever you do, do not use the phrase "Wi-Fi" as a general term for an internet connection, the VM Hub or Ethernet connections.
    • Nicholas2005's avatar
      Nicholas2005
      No bro, because I pay for most the package my mom says I can sort it if want but obviously she wants to be updated to.
      I said the issue, not to be rude it has kept rebooting alot, making some devices bandwidth causing mac address filtering blocking the device. Coverage is fine if it didn't disconnect all the time. You right but the WiFi is what is causing the WiFi to reboot.
  • Hi Nicholas2005 thanks for your post although we're sorry to hear of the concerns you've raised here.
    We have ran some checks on our side and there aren't any issues on the line we can see at the moment, how have things been for you since your post is this still ongoing for you?
    Can you come back to us with the tests as advised here in the thread?
    Many thanks
      Nicholas2005
      Hello Tom,
      It hasn't improved much it's been the normal, the one day it's fine but then another it's rebooting a couple times no reason. We then had issues where the hub restarted by itself and changed the ssid and stuff . A couple of people keep telling me to buy equipment but we pay so much we should coverd. I handle some of the stuff for the WiFi sometimes so have her permission.
      The hub 5 stopped the frequency but it happens quite a bit on some days
      Nicholas2005
      It also drops speed sometimes quite alot and can't keep up and sometimes the upstairs struggles and wonders if it's a hub5 or FTTC connection. We had a power up and down issue before but a reboot fixed it but since then we have had days where the service just sucks and we pay so much for it.
      Nicholas2005
      Is there any chance you could check why it reboots so much and struggles. We bought the biggest package hopping it would go away but still speed,reboot issues sometimes like 45% of the week.
