Nicholas2005's avatar
Nicholas2005
Network connection issues on the gigabit speed package
Hey there I'm having issues with are houses WiFi, so ever since the new hub it doesn't do it as much.
The issue is the contant disconnections, up and down speeds and it's only when we ring em up it settles again. We also have had issues where the router restarted once and forgot itself and a new ssid for the router for some reason.
It might be the power up and down levels but it gets enough wattage and fine connection. I have checked the connections multiple times.
The issue is my mom is the WiFi holder, and she pays for it out of my money but she doesn't like the hassle of the support but for a service we pay like_70-100  for this is bad. Yes we have alot of devices but even then it should handle it in bandwidth control on the DHCP. It has happend on every hub
If a support agent sees this I'm happy to pass my mom's details or have look to send a engineer if any issues or upgrades. I am 20 but she gets the money from me for better speed because my hobby and future work is internet based as a IT network technian.
Please help
  • Nicholas2005's avatar
    Nicholas2005
    If a mod sees this or support can you please send a DM about it and can pass my mom's details and you can contact her if any issues. She prob don't know about it or care much.
    Thank you
    Nicholas2005
    I also think it may be due to old Coxial cabling and water damage possibly but might just be a doggy hub 5 idk.
  • legacy1's avatar
    Get a better 3rd party router with 1Gb ports and put hub in modem mode
      Nicholas2005
      That doesn't make a difference much should it, the hub 5 is apparently plenty powerfull. Does this really make that much of a difference
      Nicholas2005
      We have a the issue on lots of are hubs from hub 3 and tbh we pay so much they should be able to fix it.
