- purtdavidOn our wavelength
Here is the Configuration tab copied & pasted:
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig fileAllowed 1 Enabled 3.1 cmreg-vmdg660-bbt076-b.cm Primary Downstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate9770 1200000450 bps 42600bytes 0 bps Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type9769 110000274 bps 42600bytes 0 bps 42600bytes Best Effort - purtdavidOn our wavelength
Here is the upstream tab copied & pasted:
Refresh data3.0 Upstream channels
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID0 49600000 41 5120 QAM 64 1 1 43100000 41 5120 QAM 64 2 2 36600000 41 5120 QAM 64 3 3 30100000 40.5 5120 QAM 64 4 4 23600000 40 5120 QAM 64 5 3.0 Upstream channels
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts0 ATDMA 0 3 18 1 1 ATDMA 0 3 18 0 2 ATDMA 0 3 22 1 3 ATDMA 0 3 18 0 4 ATDMA 0 3 23 1 3.1 Upstream channels
Channel Channel Width (MHz) Power (dBmV) FFT Type Modulation6 10 34.7 2K QAM 256 3.1 Upstream channels
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts T4 Timeouts6 OFDMA 200 74000000 56 0 - purtdavidOn our wavelength
Apologies for late reply Client62.
Here is the download tab copied & pasted:
3.0 Downstream channels
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 330000000 8.2 42 QAM 256 25 2 138000000 10.4 42 QAM 256 1 3 146000000 10.4 42 QAM 256 2 4 154000000 10.4 42 QAM 256 3 5 162000000 10.2 42 QAM 256 4 6 170000000 9.9 42 QAM 256 5 7 178000000 9.6 42 QAM 256 6 8 186000000 9.7 42 QAM 256 7 9 194000000 9.9 42 QAM 256 8 10 202000000 9.9 42 QAM 256 9 11 210000000 9.9 42 QAM 256 10 12 218000000 9.7 42 QAM 256 11 13 226000000 9.7 42 QAM 256 12 14 234000000 9.7 42 QAM 256 13 15 242000000 9.6 42 QAM 256 14 16 258000000 9.3 42 QAM 256 16 17 266000000 9.1 42 QAM 256 17 18 290000000 8.8 42 QAM 256 20 19 298000000 8.5 42 QAM 256 21 20 314000000 8.4 42 QAM 256 23 21 322000000 8.4 42 QAM 256 24 22 338000000 8.1 42 QAM 256 26 23 346000000 8 42 QAM 256 27 24 354000000 7.9 42 QAM 256 28 25 362000000 7.9 42 QAM 256 29 26 370000000 7.7 42 QAM 256 30 27 378000000 7.6 42 QAM 256 31 28 386000000 7.3 42 QAM 256 32 29 394000000 7.3 41 QAM 256 33 30 402000000 7.4 41 QAM 256 34 31 410000000 7.5 42 QAM 256 35 32 514000000 6.7 41 QAM 256 36 3.0 Downstream channels
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 Locked 42 86 109 2 Locked 42 366603 185834 3 Locked 42 440906 115706 4 Locked 42 368153 27571 5 Locked 42 279658 3952 6 Locked 42 1010846 25243 7 Locked 42 73 82 8 Locked 42 70 103 9 Locked 42 1127 700 10 Locked 42 1031 599 11 Locked 42 60 55 12 Locked 42 10 53 13 Locked 42 565 446 14 Locked 42 595 401 15 Locked 42 315 378 16 Locked 42 330 345 17 Locked 42 156 282 18 Locked 42 155 208 19 Locked 42 155 229 20 Locked 42 75 143 21 Locked 42 116 94 22 Locked 42 89 92 23 Locked 42 70 91 24 Locked 42 77 96 25 Locked 42 55 96 26 Locked 42 56 63 27 Locked 42 44 49 28 Locked 42 45 67 29 Locked 41 1330748 41364 30 Locked 41 124571 919 31 Locked 42 1832 541 32 Locked 41 889 519 3.1 Downstream channels
Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)159 94 4K 1840 QAM 4096 1108 3.1 Downstream channels
Channel ID Locked Status RxMER Data (dB) PLC Power (dBmV) Corrected errors (Active Profile) Uncorrectable errors (Active Profile)159 Locked 41 3.3 2148278111 0 Cheers in advance.Dave. - Client62Alessandro Volta
Copy and paste the text please. This is easier to read than screenshots.
Will attempt to upload them if I can blush if anyone could check if they as should be please as all gobbled de **bleep** to me blush? Much appreciated.
Pre terminated cables are available.
But do your Upstream / Downstream stats reflect a current problem with Signal Levels / Errors / Modulation modes ?
Related Content
- 17 days ago
- 9 months ago
- 4 months ago
