purtdavid's avatar
purtdavid
Is 1m or less pre-terminated coax cable for between wall outlet and hub 5 please?
Just wanted to try a pre-terminated VM coax cable between our white interior wall outlet and our Hub 5 (in modem mode) in the hall (doesn't do any Wi-Fi duties obviously blush) as just wanted to cross it off my list of possible locations for a poor connection (existing cable was engineer fitted in 2011 and regularly checked its tightly screwed up)?
Cheers in advance.
Dave
  • purtdavid's avatar
    purtdavid
    Here is the Configuration tab copied & pasted:
    Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
    Allowed
    1
    Enabled
    3.1
    cmreg-vmdg660-bbt076-b.cm
    SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
    9770
    1200000450 bps
    42600bytes
    0 bps
    Primary Upstream Service Flow
    SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
    9769
    110000274 bps
    42600bytes
    0 bps
    42600bytes
    Best Effort
    purtdavid
    Here is the upstream tab copied & pasted:
    Refresh data
    3.0 Upstream channels
    049600000415120QAM 641
    143100000415120QAM 642
    236600000415120QAM 643
    33010000040.55120QAM 644
    423600000405120QAM 645
    0ATDMA03181
    1ATDMA03180
    2ATDMA03221
    3ATDMA03180
    4ATDMA03231
    3.1 Upstream channels
    61034.72KQAM 256
    6OFDMA20074000000560
    purtdavid
    Apologies for late reply Client62.
    Here is the download tab copied & pasted:
    3.0 Downstream channels
    13300000008.242QAM 25625
    213800000010.442QAM 2561
    314600000010.442QAM 2562
    415400000010.442QAM 2563
    516200000010.242QAM 2564
    61700000009.942QAM 2565
    71780000009.642QAM 2566
    81860000009.742QAM 2567
    91940000009.942QAM 2568
    102020000009.942QAM 2569
    112100000009.942QAM 25610
    122180000009.742QAM 25611
    132260000009.742QAM 25612
    142340000009.742QAM 25613
    152420000009.642QAM 25614
    162580000009.342QAM 25616
    172660000009.142QAM 25617
    182900000008.842QAM 25620
    192980000008.542QAM 25621
    203140000008.442QAM 25623
    213220000008.442QAM 25624
    223380000008.142QAM 25626
    23346000000842QAM 25627
    243540000007.942QAM 25628
    253620000007.942QAM 25629
    263700000007.742QAM 25630
    273780000007.642QAM 25631
    283860000007.342QAM 25632
    293940000007.341QAM 25633
    304020000007.441QAM 25634
    314100000007.542QAM 25635
    325140000006.741QAM 25636
    1Locked4286109
    2Locked42366603185834
    3Locked42440906115706
    4Locked4236815327571
    5Locked422796583952
    6Locked42101084625243
    7Locked427382
    8Locked4270103
    9Locked421127700
    10Locked421031599
    11Locked426055
    12Locked421053
    13Locked42565446
    14Locked42595401
    15Locked42315378
    16Locked42330345
    17Locked42156282
    18Locked42155208
    19Locked42155229
    20Locked4275143
    21Locked4211694
    22Locked428992
    23Locked427091
    24Locked427796
    25Locked425596
    26Locked425663
    27Locked424449
    28Locked424567
    29Locked41133074841364
    30Locked41124571919
    31Locked421832541
    32Locked41889519
    3.1 Downstream channels
    159944K1840QAM 40961108
    159Locked413.321482781110
    Cheers in advance.
    Dave.
    Copy and paste the text please.    This is easier to read than screenshots.
    purtdavid
    Will attempt to upload them if I can blush if anyone could check if they as should be please as all gobbled de **bleep** to me blush? Much appreciated.
    Pre terminated cables are available.
    But do your Upstream / Downstream stats reflect a current problem with Signal Levels / Errors / Modulation modes ?
