Intermittent dropouts and very busy omnibox?
Good morning!
Not really sure where to start with this, but just after some advice.
I'm on a Gig1 package from VM. Currently having constant intermittent dropouts every so often (these are so severe that they're affecting online gaming, getting kicked back to the lobby etc.). See attached photo of one of the many dropouts.
Working in IT, I have my own setup. It's a basic network that pretty much goes like this: Hub 4 (modem mode) > Unifi Security Gateway > Switch > PC. I prefer to wire all of my equipment when possible. Wi-fi is managed by 2x Ubiquiti AP's. VM will often try to tell me that my network is configured incorrectly etc. I'm 99% sure I've configured my network correctly. It's a basic network without any VLAN's and the most 'advanced' thing on it is a L2TP VPN that I set up.
Taking a peek at the omnibox outside the house, I have noticed another connection has been added. We're now on 1 in and 3 out on this line, is this normal?
I've reset the hub 4 back to default factory settings as advised, but this hasn't helped. All Ubiquiti updates applied. I have a replacement hub 5 coming on Saturday but just wondered if it's normal to have such a busy omnibox?
I'm not able to view the signal strength of the line as my Hub 4 doesn't allow me to log into the web management page. To get into this, I'll need to reboot the hub and quickly try to log into the hub when it comes back on. Even after rebooting the hub, the web management page will only work for 5 minutes before dying and refusing to load anything else... something on the backend isn't playing nicely.
Oh - I forgot to say - the splitter might be duff and not passing upstream properly, in which case the associated neighbour will be suffering the same as you.
