Scoose's avatar
Scoose
Just joined
4 days ago
Intermittent connection issues, post RS and uncorrectable errors on router
Have had Virgin media out three times regarding this. They eventually replaced the cable to the running from the box in the street to the house (but not the internal cables). It has improved slightly with total disconnects being less frequent, but the values shown below from the router indicate issues still. He also attenuated the cable at the router.
This is only approx 1 week uptime following a factory reset and every channel already has 20 - 50 Post-RS errors. The 3.1 downstream is also a huge number or correctable and uncorrectable errors.
What can be done about this?
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
6.6
42
QAM 256
25
2
139000000
8.8
41
QAM 256
1
3
147000000
8.6
41
QAM 256
2
4
155000000
8.5
41
QAM 256
3
5
163000000
8.4
41
QAM 256
4
6
171000000
7.9
41
QAM 256
5
7
179000000
8.1
41
QAM 256
6
8
187000000
7.9
41
QAM 256
7
9
195000000
7.6
41
QAM 256
8
10
203000000
7.7
41
QAM 256
9
11
211000000
7.6
41
QAM 256
10
12
219000000
7.4
41
QAM 256
11
13
227000000
7.5
41
QAM 256
12
14
235000000
7.5
41
QAM 256
13
15
243000000
7
41
QAM 256
14
16
251000000
7.1
41
QAM 256
15
17
259000000
7.2
41
QAM 256
16
18
267000000
7.1
41
QAM 256
17
19
283000000
7.2
42
QAM 256
19
20
291000000
6.9
41
QAM 256
20
21
307000000
7
42
QAM 256
22
22
315000000
6.6
42
QAM 256
23
23
323000000
6.9
42
QAM 256
24
24
355000000
6.5
42
QAM 256
28
25
363000000
6.4
41
QAM 256
29
26
379000000
6.9
42
QAM 256
31
27
387000000
6.7
42
QAM 256
32
28
395000000
7.2
42
QAM 256
33
29
411000000
7.5
42
QAM 256
35
30
419000000
7.7
42
QAM 256
36
31
427000000
7.7
42
QAM 256
37
32
451000000
7.2
42
QAM 256
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
42
210
38
2
Locked
41
225
51
3
Locked
41
221
48
4
Locked
41
233
38
5
Locked
41
232
42
6
Locked
41
218
37
7
Locked
41
207
42
8
Locked
41
212
35
9
Locked
41
206
37
10
Locked
41
210
36
11
Locked
41
223
42
12
Locked
41
213
38
13
Locked
41
215
40
14
Locked
41
196
32
15
Locked
41
178
36
16
Locked
41
193
41
17
Locked
41
178
41
18
Locked
41
193
47
19
Locked
42
194
41
20
Locked
41
199
35
21
Locked
42
206
43
22
Locked
42
179
70
23
Locked
42
197
45
24
Locked
42
211
42
25
Locked
41
211
37
26
Locked
42
199
50
27
Locked
42
203
37
28
Locked
42
210
33
29
Locked
42
192
29
30
Locked
42
195
32
31
Locked
42
176
42
32
Locked
42
169
27
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
94
4K
1840
QAM 4096
1108
Channel ID
Locked Status
RxMER Data (dB)
PLC Power (dBmV)
Corrected errors (Active Profile)
Uncorrectable errors (Active Profile)
159
Locked
37
1.4
166284222
3000992701
1 Reply
  • Hi Scoose
    Thanks for posting and welcome to the community. Sorry to hear of any Broadband issues. We've not been able to locate you via the Forum details.
    Are there any issues listed on our status page - https://www.virginmedia.com/help/check/status pop the surname of the account holder and also the postcode in. Any issues will be shown and you can also run a fault test on your equipment.
    Keep us posted.
