JHayd
4 months agoSettling in
Hub5 Ethernet problem
I am having an issue with the Hub5 not sharing WiFi and Ethernet connection and have no idea what to try next.
WiFi works ok in the house until I plug in an Ethernet cable. As soon as I connect one into any of the normal gig ports, the WiFi immediately drops.
We have large outbuildings that need the DVR on Ethernet for the security feed that covers the entire house. This is wired up by a CAT6 cable. The speed of the internet is fine in the outbuilding and on the DVR but it is taking the whole connection and dropping the WiFi.
I have changed the cables, performed a factory hard reset, checked that DCHP is enabled etc.
A main frustration is that I can’t access the Smart Hub online when I plug the ethernet in as WiFi drops.
