cohnen
1 year agoJoining in
HUB3 Red Light
For the past 2 months my hub 3 has been showing a red light, the connection seems fine, speed tests look normal, and the online hub test shows no issues.
I have done multiple pin hole resets and as suggested I unplug it when I’m asleep or out of the house in case of a fire.
Some assistance with replacing the hub would be appreciated thank you.
