metalmatt's avatar
metalmatt
Superfast
Hub 5 status Cable Modem Status
I currently have a hub 5 and on M250 Fibre Broadband service. When I look at the hub status page it tells me that my Cable Modem Status Online is DOCSIS 3.0 should it say DOCSIS 3.1?
Cable Modem Status
Item Status Type
Cable Modem Status Online DOCSIS 3.0
Primary downstream channel Locked SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels 31 5
DOCSIS 3.1 channels 1 1
  • The primary downstream channel is always DOCSIS 3.0.  When you Hub is powered on with Coax connected it needs a simple channel to do receive the stuff coming its way.  Likewise for upstream.  At that point, the sub-channels of DOCSIS 3.1 haven't been allocated and won't be until all the registration formalities have been completed.
  • Sephiroth's avatar
    Sephiroth
    Hub 4 & Hub 5 both run a mix of multiple 3.0 channels and a single 3.1 channel,
    we can see that is working as expected in the last couple of lines of your post.
