Greenwood35's avatar
Greenwood35
Hub 5 keeps disconnecting and flashing red
I've had no luck getting through to a human on the phone so I hope this will help.
For the last 24 hours our Hub 5 has been constantly losing connection. It regularly goes into a state where the red light flashes over and over.
And even when it does come back on, sometimes we're left with only a 10th of what our internet speed should be.
We had it fitted in December and it was fine until now.
It's not overheating, is connected properly and is in a well ventilated area. We've tried all methods of refreshing, restarting and resetting and we're worried this issue will keep happening.
Every time I call or check on the app/online it simply states that everything is fine, which is obviously not the case.
It seems to be working fine now, but it's only a matter of time before it goes down again.
We both work from home so this is affecting our work quite severely.
Also, the WiFi connection is poor/non existent at the living room end of our flat (all one single level, ground floor), so if this could be addressed too that would be great, otherwise we'll have to explore other provider options.
Any help will be greatly appreciated.
A technician visit, a new hub, maybe pod extenders?
Thank you.
1 Reply
  • jbrennand's avatar
    See this
    ________
    First thing is to check for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    If there are no issues and its still flaky post up the connection data/details as per below and re. thee wifi see the second post below.
    _________________________
    In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    ____________________________________________________
    To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
    You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
    If not free to you… you will be charged £8/month for up to 3 pods (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
    If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point(s), (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
    £40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
