clockworksatan's avatar
Hub 5.0 DHCP Issues
I just upgraded to the Hub 5.0 on VM's 1gig connection.  I previously had the Hub 3.0 and had to switch it to modem mode as its WiFi was quite frankly rubbish, and I was hoping that the new Hub would be a vast improvement.  Initially, I was impressed with the WiFi speed (I even said 'wheee' when doing a speedtest), but when it came to me trying to assign a static IP to my NAS, I keep encountering an odd issue.
When I go into the DHCP settings and select my NAS, it displays the following:
It doesn't matter what IP address I put in there; it always says that it's not a valid IP address.  I mean, wth?  Don't tell me that this shiny, modern router doesn't in fact have basic router functionality?  Anyway, I called VM this morning to see if they had any words of wisdom, but the rep on the other end of the phone was completely useless and didn't seem to have the slightest clue what I was talking about.
From the posts I've seen on this already, I gather that there's no fix for this and I've not missed anything obvious?  I've got a feeling that I'm going to switching this new hub to modem only too, which is annoying as the router I've got isn't a WiFi 6 one.
    Hub 5 DHCP has always been as flaky as chocolate.
    Configure the NAS to a static IP outside of the DHCP range.
  • legacy1's avatar
    For the best experience with VM get your own router with 1Gb ports and use hub in modem mode
  • Roger_Gooner's avatar
    Roger_Gooner
    Use the dynamically assigned IP address, that's how I did it for my NAS (it's 192.168.0.17).
  • Tudor's avatar
    You are not giving the NAS a static IP address doing it on the VM hubs, you are only giving it a ‘preferred’ IP address. You can only give a device a static IP address by doing it on the device. Preferred IP addresses allocated on a HUB or router are always wrongly called static addresses. If you give a device a ‘preferred’ IP address you get twice the amount of DHCP traffic as a static address on the device.
      Roger_Gooner
      I disagree. There is an initial DHCP negotiation process which occurs regardless of whether a NAS uses a static IP or a  DHCP-reserved IP. Subsequently if the NAS reconnects or if the lease needs renewal, some additional DHCP traffic will occur but this is trivial.
      For most people I recommend DHCP reservation as all IP assignments are in one place and, of course, many  devices such as mobile and IoT devices do not provide the means to statically set their IP addresses.
      • Tudor's avatar
        For a ‘reserved’ DHCP, at least on my router, you get:
        DHCPDISCOVER
        DHCPOFFER
        DHCPREQUEST
        DHCPACK
        For a ‘static’ device you get:
        DHCPREQUEST
        DHCPACK
        I agreed most IoT WiFi devices do not provide facilities to have a ‘static’ IP address, but all Apple devices certainly allow it, I use it on all of mine.
    • clockworksatan's avatar
      clockworksatan
      I was indeed being a dummy and have updated my NAS settings so that it's properly set to a static IP and it's now working with my Hub 5.0.  Thank you for your help!
      • Akua_A's avatar
        Akua_A
        Hi clockworksatan
        Welcome back to our community forums and sorry to hear you were having DHCP Issues. We are glad to see the community was able to help with this. Please do not hesitate to contact us if you need any further help.
