robatwork's avatar
robatwork
Hub 5 / 192.168.0.1 / Change IP range
Just bought a new Hub 5 to replace a Hub 3, to help with wifi speeds.
Having had a quick root around here it looks like VM removed the ability to change the IP range, which is going to cause me a problem as I VPN into work which is on 192.168.0.0/24.
Other than using my own router behind the Hub 5 in modem mode (which I don't want to do for various reasons), is there a secret unpublished method to change the hub's IP that I haven't discovered in a quick google? My DM's, as they say on X, are open.
Thanks in advance
  • Though there is no place to change the IP address directly. You can change the last 2 numbers on the DHCP range start.
    I set mine to start at 192.168.4.101 and voila, the IP address of the router changed to 192.168.4.1
    So, you can't change the router IP address to anything but it gives some flexibility.
    • thestantons8's avatar
      thestantons8
      This is what I need to do, to use a range other than 192.168.0.x as it conflicts with the work VPN which has a huge number of rules applied.
      With the hub 3, I was able to set DHCP to allocate from 192.168.10.x yet the hub 5 prompt says '192.168.0.' as the fixed prefix on the DHCP page.
      I can't see where to change the last 2 digits, how did you do it please?
      • Tudor's avatar
        You can NOT now change the LAN DHCP range on any VM hubs, they are locked down. Your only option is to get your own router and run the hub in modem mode.
    • robatwork's avatar
      robatwork
      I left VM so can't test this. Can anyone else confirm this is the (peculiar) way around the issue?
  •  I don't remember any such issues with changing the LAN IP network and I've had a hub2, 3 and 5, are you looking in the Advanced Admin section?
      robatwork
      I've checked every option in every menu, looks like the newer fw has locked it down beyond reason. All that can be changed in DHCP is the starting local address and the number of CPEs. Not the actual DHCP server address.
  • Tudor's avatar
    Speak to you work IT, you cannot now change the local LAN IP subnet.
      robatwork
      I am my work IT 😀
      It would be such a PITA to change the work IP range as to not be realistic
      • jpeg1's avatar
        jpeg1
        You don't buy the Hub from Virginmedia. It is loaned to you during the contract.
    "bought a Hub 5" ... Do you mean as in bought a Hub 5 from eBay ?
    Hub 3 and Hub 5 both use the same LAN  IP range, why has this only become an issue now with the Work VPN ?
      robatwork
      As in "bought direct from Virgin Media after a request to their cust service dept"
