- jbrennandVery Insightful Person
First try deleting and reinstalling the App
- peteclenTuning in
Sorry, didn't help
- Ilyas_YForum Team (Retired)
Hi there peteclen Thanks for reaching out to us on the Virgin Media forums. 👋🏼
I'm sorry to hear about the issues with the Virgin Media Connect app. 😞
May I ask what device you are using and what operating software it is on? Have you downloaded the latest version of the app?
Are you able to download the app on another device and see if it works there? Please also try to clear all app cache data and cookies and see if it works after.
Let us know how it goes.
Kind regards,
Ilyas.
- Client62Alessandro Volta
Check that you can still login to the Hub menu at http://192.168.0.1/ i.e. it accepts the password and displays a working menu.
If the Hub 4 menu has failed again, that also appears to block access for the VM Connect app or to leave the VM Connect app stuck in an Optimize Wi-Fi loop.- peteclenTuning in
No longer able to login to hub. Appears to accept password, then... Nothing.
Also, WiFi signal erratic, even near hub. In other rooms it's poor. Obviously, unable to confirm speed with VM Connect, but Ookla speed test shows 7.60Mb download, 7.53Mb upload in next room. I'm on 1Gb!
- legacy1Alessandro Volta
you need a better wifi router with 1Gb ports then VM can do with hub in modem mode
- peteclenTuning in
Before moving to hub4, I had a tplink mesh system, with hub in modem mode. VM Connect app wont work in modem mode
- Kain_WForum Team (Retired)
Hi peteclen,
Gareth is currently out of office so I've assigned this to myself to gain a further update.
I've dropped you a PM so we can discuss further.
The message will appear within the envelope icon.
Regards,
Related Content
- 2 years ago
- 1 year ago
- 2 years ago
- 1 year ago
