SweetFA's avatar
SweetFA
Hub 3 solid red light.
Hello Virgins. ✌🏼
As the title suggests! The light at the front has a solid red light instead of the solid white.
This hasn't changed after a reboot and a reset. 🤷🏼‍♂️
My understanding is that a new hub is needed 🙄
I look forward to hearing from VM.
Many thanks. 👍🏼
  • Hi SweetFA, thank you for your post.
    We're sorry to hear about the problem you're having 😔
    In order to discuss this with you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Regards,
    Daniel
  • I have the same issue. Solid red light on the router for a long time. I think this might be an overheating issue. Can someone help please?
    • Kath_P's avatar
      Kath_P
      Hi mtalbot2987,
      We're very sorry to hear you're having some issues with your Hub 3 displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red at times. This is perfectly normal and nothing to worry about.
      If it's not then please follow the below steps:
      • ➡ Turn the power switch off on the back of the Hub.
      • ➡ Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight.
      • ➡ Then use the power switch to turn the unit back on. The Hub should now operate normally.
      If the red light still shows after doing the above, pop back here and let us know. We can then arrange an engineer to visit to swap out the Hub.
  • Hi - my Hub 3 has also had a solid red light for several weeks, although I've started to experience connection drop-outs and instability over the last few days.
    I've tried the recommended initial steps to perform a factory reset and check all wired connections, but the light remains solid red.
    Looking on this forum, this issue seems quite common, so I'd appreciate it if someone could help out, many thanks!
    • adampb's avatar
      adampb
      Apologies, I decided it would be clearer to create a separate post for my specific issue, as this post is "solved". Please disregard the above reply, thanks.
      • Akua_A's avatar
        Akua_A
        Thank you for letting us know adampb We can see you have been able to get an appointment booked to resolve this issue. Please do not hesitate to contact us if you need any further help.
    Regards,
    Daniel
