Jokes1000's avatar
Jokes1000
Hub 3 RED LIGHT
Hi All.
I’ve been experiencing red light issues now for up to 2+ years. Called vm on numerous occasions. It will be logged their end multiple times, i just seem to get fobbed off all the time. The red light clearly means the device is over heating and has issues. Tried everything and basically hub is faulty, clearly over heating or some other issue. If its over heating then clearly not safe either!! I have been pushing for a new hub for years, its like pulling teeth trying to make contact with anyone. I’m at the point of giving up, even bought a new third party router and put the useless virgin one in modem mode. Still have red light and it should be magneta in modem mode. Virgin if you’re listening PLEASE send me a new hub!! I am a paying customer after all. Thanks
  • Also, pointless running through all the checks again for the ten millionth time. Just needs a new hub. Thanks.
      If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
    • Kath_P's avatar
      Kath_P
      Hi Jokes1000,
      We're very sorry to hear you're having some issues with your Hub 3 displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red at times. This is perfectly normal and nothing to worry about.
      We won't be able to fix this remotely so I'd like to arrange a hub replacement for you and we need an engineer to come out to do this. I just need to confirm the address to move forward on this.
      I've sent you a direct message to allow us to do this with you in a private space. If you're using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you're on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
      • Jokes1000's avatar
        Jokes1000
        Hi. Thanks for the reply. I have direct messaged you my details. Definitely not magenta. Its been red for years and nothing has been done about it. Thanks
  • I've had the redlight and total outage for 14 days. Outage affected whole area for 3 days but mine didnt come back when they'd 'fixed' it). Engineers came twice and agreed my equipment NOT faulty so fault is external but seems like they've given up trying to fix it now because I've cancelled my services.  Guess they'll still expect the bill to be paid?
    Time line:
    8 Feb, total outage in area
    New bill issued (£72 for wifi only)
    11 Feb, apparently fixed
    13 Feb, engineer failed to attend but its ok, CS told me I shouldn't have booked it online!
    15 Feb, engineer came, tested my equipment, is ok. Tested line thats outside my door, totally dead. Can't access their equipment cos its in a locked cupboard for which he has to get keys from housing dept.
    19 Feb, 2nd engineer came. Tested my equipment, all ok. Tested outside line, totally dead. Can't access their eqipment because its still in the locked cupboard and they haven't liaised with local housing to get the keys.  Made 3rd appointment for tomorrow but still wont have the keys.
    I phoned to cancel my service, bit pointless paying £70/month for service I dont have.  CS tell me I should call housing for keys - ofcourse, they're going to give me a set of keys for doors marked 'DANGER: ELECTRICAL'.
    Cancelled service, so they cancelled tomorrows engineer visit but I have to pay for another 30 days of non-service. wth??
    Arranged installation of wifi from alternative company for 21 Feb.
    20 Feb, repeated calls from Virgin retentions - how do they even think I want to stay for a service that I can't receive?
    21 Feb, new service being jnstalled as I type:)
      You should be due compensation for loss of service after 48 hours?
      • Morwendy's avatar
        Morwendy
        Yes, once its fixed but they're not even trying to fix it now. When I called to cancel service, they cancelled engineers next planned visit too.  Useless service and the CS reps...I'm guessing they just pull them in off the street; the English guy I spoke to to cancel couldn't even understand what the call centre guy had written on my account
