Micgav7580
1 year agoJoining in
Hub 3 Red Light
I have the same problem with my hub 3. It is warm to the touch (the top of it) but it is not overly warm or hot. I have turned it off twice (once overnight) and tried the pinhole reset and I have also checked the cables in the back and none of them are loose. There are no issues with the wifi signal and it's not dropping out. I am concerned as advice given to others say that a permanent red light means possible overheating. The modem is well ventilated and doesn't have anything blocking the back or either side of it.
Can someone please advise me what I should do? If you post a reply or private message me would I get an email notification or do I have to come back here to check?
I look forward to hearing from you.
