terraloam72's avatar
terraloam72
Hub 3 Red Light Stays On
Hi, we reconnected our Hub yesterday after 2 months whilst we had building work carried out in the house. Our Hub 3 now has a permanent red light showing, never had issues before. We do appear to have internet though.
I have reset a few times including 30 sec press of reset button at back. Feels slightly warm to touch, should I be concerned about overheating?
Regards,
    Run the Network diagnostic tool ( from the Hub 3 menu )
    Scroll down through the results and find the Temperature entry.   Is it normal ?
    • terraloam72's avatar
      terraloam72
      Thanks for your reply. Yes, temperature normal.
      Possibly starting to have other issues as well as permanent red light. A few times hub has lost internet connection and when I 'check service status; and click 'Test your Hub' every time it says 'Looks like we nee to reset the Hub'.
      • Reece_MH's avatar
        Reece_MH
        Hi terraloam72 👋
        Thanks for posting, and a warm welcome to the Forums.
        I'm very sorry to hear you're seeing a red light on your Hub. I'm going to send you a private message to assist further. Please look out for it in the top-right, white envelope or by tapping your profile picture and selecting "Messages".
  • Issues resolve!! VM very quick in sending an engineer to replace hub and check connections etc. 🙂
