Pjeffery1's avatar
Pjeffery1
Just joined
25 days ago
Hub 3 red light.
My VM hub 3 has had a red light on for several months now. I have reset , unplugged, but to no avail. In the past few weeks it has started to reboot itself, and as such drops the WiFi. I have done speed tests via VM app when it's working but this is becoming tiresome now. Please advise me how I can resolve this problem.
  • Hey Pjeffery1, thank you for reaching out and we are sorry to hear about your red light issues, also a very warm welcome to the community.
    Please do try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
     We will also send you a PM now.
    • Matthew_ML's avatar
      Matthew_ML
      Glad we've got the ball rolling on this for you :)
      • Pjeffery1's avatar
        Pjeffery1
        Just joined
        Engineer visited, found a wire had broken down and replaced router
         All sorted now thank you.
