Pkay1's avatar
Pkay1
Hub 3 Problem
I understand that there should be 4 working ethernet ports on the Hub3. Only one port working. All tests say my system is working fine. Full reset on hub carried out to no avail. Can't seem to get anyone from VM to discuss the issue.
  • Are you sure the Hub is not in modem mode? In that mode, only one ethernet port will work.
  • jpeg1's avatar
    jpeg1
    • Pkay1's avatar
      Pkay1
      Thank you for your reply. Apparently if the Hub3 was in modem mode the WiFi would not work.The WiFi is working really good.
      • Kath_P's avatar
        Kath_P
        Hi PKay1,
        We're sorry to hear the ethernet ports on the hub are not working. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
        I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
