Pkay1's avatar
Pkay1
3 months ago
Hub 3 Problem
I understand that there should be 4 working ethernet ports on the Hub3. Only one port working. All tests say my system is working fine. Full reset on hub carried out to no avail. Can't seem to get an...
  • jpeg1's avatar
    3 months ago
    Are you sure the Hub is not in modem mode? In that mode, only one ethernet port will work.
