d219's avatar
d219
Hub 3 has started regularly showing red light
I seem to be having the same issue as https://community.virginmedia.com/t5/Networking-and-WiFi/Re-Red-light-hub-3/td-p/5475794 (where the resolution was an engineer replacing with hub 5). Tried going through the phone but it was sending me down the path of resetting router etc for a broadband signal problem, which is fine, so trying here instead 🙂
To summarise:
  • Red light has started regularly appearing over the last 10 days - 2 weeks (most of the time it seems to be red, but sometimes an amber)
  • Tried turning hub off for an extended period but did not resolve
  • Hub is not impeded by anything else around it, so should have decent airflow
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Ayisha_B's avatar
    Ayisha_B
    Hi d219 👋
    Welcome to our Community Forums and thanks for your post.
    I'm so sorry to hear that you're facing some issues with your Hub 3 displaying a red light. Please follow the below steps in the first instance.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If the issue remains despite following the above, please respond to the private message 📩  that I'll be sending to you shortly and we can go from there.
  • Ayisha_B's avatar
    Ayisha_B
    Thanks for confirming the requested details via PM d219
    I've booked an engineer for you to come out and have the hub replaced. You can find confirmation of the visit via your 👉 online account.
    Let me know if there are any problems with the date or time and I can look to reschedule this for you.
    Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can also do this online or via the MyVM app by 4pm the day before the appointment.
    If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
    Let us know how the visit goes!
  • d219's avatar
    d219
    Thanks - engineer agreed the hub was faulty and swapped it out with a replacement. All good now.
