1 Reply
- Client62Alessandro Volta
no RF connection = the no signal from the VM Network, unless there is a loose cable in your home this is a fault that VM have to fix & may also affect the homes local to you.
Check for known faults in your street ( use both methods )
Call the local fault line: 0800 561 0061 – this is an automated number.
https://www.virginmedia.com/help/check/status/identification/identify
Related Content
- 2 years ago
- 1 year ago
- 5 months ago
- 2 years ago
- 1 year ago
