nik-handson
1 year agoJoining in
How to connect Cat6 cables in 1 room to Hub5 in another
Hi, I'm currently nearing the end of a home renovation project where we've had a utility room built, featuring a cupboard that I've asked the builders to run Cat6 cables to. These cat6 cables connect to ports in rooms of the house which will allow us to have a hardwired connection to various devices.
Currently our Hub5 sits in our lounge next door to the utility room.
What would be the best way to connect the cat6 cables to the Hub5? Can I use a wireless router, linked to a network switch for the cables to plug into in the utility room, and connect the router to the Hub5 wirelessly if I put the Hub5 in modem mode? Would this work or is there a better solution?
Many thanks!
