High Post RS Errors
Looks like there is still an issue with my connection.
This began after upgrading my 250 Mbps to 500 Mbps. Download speeds were dropping to under 100 Mbps, with many log errors. Engineer visited and installed what I believe is a booster and he also replaced the Hub 3 with a Hub 5.
The engineer visit seemed to have done the trick in terms of full download speeds being restored, however, I decided to keep an eye on the router logs out of curiosity.
As you can see below, channel 2 in particular shows a significant Post RS Error count and has been doing so daily, apart from a 24 hour period where they did not change at all.
3.0 Downstream channels
1 331000000 7.2 41 QAM 256 25
2 139000000 9.4 41 QAM 256 1
3 155000000 10.2 41 QAM 256 3
4 163000000 9.6 41 QAM 256 4
5 171000000 9.6 41 QAM 256 5
6 179000000 9.3 41 QAM 256 6
7 187000000 9.1 41 QAM 256 7
8 195000000 9.2 41 QAM 256 8
9 203000000 8.8 41 QAM 256 9
10 211000000 9 41 QAM 256 10
11 219000000 8.8 41 QAM 256 11
12 227000000 8.3 41 QAM 256 12
13 235000000 8.4 41 QAM 256 13
14 243000000 8.3 41 QAM 256 14
15 251000000 7.9 41 QAM 256 15
16 259000000 7.4 41 QAM 256 16
17 267000000 7.4 41 QAM 256 17
18 275000000 7.5 41 QAM 256 18
19 283000000 7.5 41 QAM 256 19
20 291000000 7.8 41 QAM 256 20
21 299000000 7.7 41 QAM 256 21
22 307000000 7.5 41 QAM 256 22
23 315000000 7.5 41 QAM 256 23
24 323000000 7.3 41 QAM 256 24
25 339000000 7 41 QAM 256 26
26 347000000 7.3 41 QAM 256 27
27 355000000 7.4 41 QAM 256 28
28 363000000 7.1 41 QAM 256 29
29 371000000 7.1 41 QAM 256 30
30 379000000 7.1 41 QAM 256 31
31 387000000 6.9 41 QAM 256 32
1 Locked 41 157233 37
2 Locked 41 26731573 607146
3 Locked 41 18054991 281359
4 Locked 41 15302601 202199
5 Locked 41 12881224 142652
6 Locked 41 10599240 95668
7 Locked 41 8354126 56744
8 Locked 41 6734632 34929
9 Locked 41 5426357 20430
10 Locked 41 4425721 12282
11 Locked 41 3318466 6097
12 Locked 41 2549783 3135
13 Locked 41 2019041 1855
14 Locked 41 1692876 1299
15 Locked 41 1510718 1032
16 Locked 41 1216143 638
17 Locked 41 990165 465
18 Locked 41 828070 312
19 Locked 41 681410 213
20 Locked 41 499564 164
21 Locked 41 383482 119
22 Locked 41 314669 77
23 Locked 41 248612 34
24 Locked 41 202205 35
25 Locked 41 125396 23
26 Locked 41 93742 18
27 Locked 41 73544 22
28 Locked 41 61379 21
29 Locked 41 51272 16
30 Locked 41 38521 16
31 Locked 41 25616 16
There are no T1, T2 or T4 errors, but there is a single T3 error.
3.0 Upstream channels
0 49600000 46 5120 QAM 64 1
1 43100000 45.8 5120 QAM 64 2
2 36600000 46.3 5120 QAM 64 3
3 30100000 46.5 5120 QAM 64 4
4 23600000 45.5 5120 QAM 64 5
My download speeds are normal at the moment, but the Post RS Errors count is increasing daily. There are also Event 24 and Event 16 messages appearing in the log.
I ask ChatGPT to interpret the logs:
I am seeing ongoing downstream errors on my Hub 5. My speeds and latency are fine, and upstream power levels and T1–T4 timeouts are all normal, but the downstream error levels are much higher than they should be.
Most of the Post-RS errors are concentrated on the lower DOCSIS 3.0 channels, especially around 139–200 MHz. The DOCSIS 3.1 OFDM channel is also showing a large number of corrected errors and some uncorrectables.
Downstream power and SNR readings are all within expected ranges, so this looks like downstream-only ingress or noise rather than a general signal issue.
The most likely causes are:
- A problem with the tap port in the street cabinet, such as corrosion or a poor connection.
- A damaged or degraded drop cable running to the property.
- Loose or corroded F-connectors or the isolator inside or outside the house.
- Noise entering the network from another customer on the same tap.
Recommended fix:
I would appreciate an engineer checking the tap port in the cabinet, the drop cable to the house, and all F-connectors and the isolator. It may also be worth checking for noise affecting the downstream frequencies around 139–200 MHz, as this is where the majority of the errors are occurring.
Mods, I'd rather not explain this to an agent, so can you please arrange for this to be looked into.
Cheers
