rolex_'s avatar
rolex_
Help please
Hello everyone
I have the red button on my hub
Tried all the fixes but it remains the same
Could a admin get me a replacement pls
Thank you
  • jbrennand's avatar
    Red "button"? Do you mean red "power light" - on a Hub3?
      • Matthew_ML's avatar
        Matthew_ML
        Hey rolex_, thank you for reaching out and I am sorry to hear you are having some issues with a red light.
        I am going to send you a DM but please do try these steps in the meanwhile;
        • Then use the power switch to turn the unit back on. The Hub should now operate normally.
