martinto
1 year agoJoining in
FTTP Connection Failing Frequently
I have had my connection drop three times since 11am yesterday. I tried support earlier today but they are only able to follow a script and as I am using the Hub 3 in modem mode I gave up. The VM support people need better training to know when following a script won't help.
I'm seeing these errors:
29/03/2025 12:02:6 | Warning! | RCS Partial Service;CM-MAC[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 12:02:6 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 12:01:36 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 12:01:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:56:32 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED]CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:56:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:56:15 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=0[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:56:15 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:54:18 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:54:18 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:54:15 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:54:14 | notice | LAN login Success;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:53:1 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=0[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:53:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=4[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:52:53 | Warning! | RCS Partial Service;CM-MAC[REMOVED];CMTS-MAC=[REMOVED]CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:52:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:49:42 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:49:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:47:39 | Warning! | RCS Partial Service;CM-MAC=[REMOVED];CMTS-MAC=0[REMOVED];CM-QOS=1.1;CM-VER=3.0; |
| 29/03/2025 11:47:28 | notice | NOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=[REMOVED];CMTS-MAC=[REMOVED]QOS=1.1;CM-VER=3.0; |
Here's the channel data...
| Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
| 1 | 138750000 | 1.9 | 37 | 256 qam | 1 |
| 2 | 146750000 | 2.2 | 37 | 256 qam | 2 |
| 3 | 154750000 | 2.2 | 38 | 256 qam | 13 |
| 4 | 162750000 | 2.2 | 37 | 256 qam | 24 |
| 5 | 170750000 | 2.5 | 37 | 256 qam | 27 |
| 6 | 178750000 | 2.4 | 37 | 256 qam | 28 |
| 7 | 186750000 | 2.5 | 37 | 256 qam | 29 |
| 8 | 194750000 | 2.2 | 38 | 256 qam | 30 |
| 9 | 266750000 | 2 | 38 | 256 qam | 9 |
| 10 | 274750000 | 1.7 | 38 | 256 qam | 10 |
| 11 | 282750000 | 1.5 | 37 | 256 qam | 11 |
| 12 | 290750000 | 1.4 | 37 | 256 qam | 12 |
| 13 | 298750000 | 1.2 | 37 | 256 qam | 14 |
| 14 | 306750000 | 1 | 37 | 256 qam | 15 |
| 15 | 314750000 | 1.2 | 37 | 256 qam | 16 |
| 16 | 322750000 | 1.2 | 37 | 256 qam | 17 |
| 17 | 330750000 | 1.2 | 37 | 256 qam | 18 |
| 18 | 338750000 | 1 | 37 | 256 qam | 19 |
| 19 | 346750000 | 1 | 37 | 256 qam | 20 |
| 20 | 354750000 | 1 | 37 | 256 qam | 21 |
| 21 | 362750000 | 1.2 | 37 | 256 qam | 22 |
| 22 | 370750000 | 1.4 | 37 | 256 qam | 23 |
| 23 | 378750000 | 1.5 | 37 | 256 qam | 25 |
| 24 | 386750000 | 1.7 | 38 | 256 qam | 26 |
| Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
| 1 | Locked | 37.3 | 3261 | 16646 |
| 2 | Locked | 37.6 | 3047 | 15985 |
| 3 | Locked | 38.6 | 2890 | 17542 |
| 4 | Locked | 37.6 | 2774 | 18691 |
| 5 | Locked | 37.6 | 2799 | 18014 |
| 6 | Locked | 37.6 | 2860 | 19067 |
| 7 | Locked | 37.3 | 2809 | 17988 |
| 8 | Locked | 38.9 | 2803 | 18912 |
| 9 | Locked | 38.6 | 2740 | 18911 |
| 10 | Locked | 38.6 | 2874 | 19388 |
| 11 | Locked | 37.6 | 2818 | 18843 |
| 12 | Locked | 37.3 | 2854 | 19148 |
| 13 | Locked | 37.6 | 2895 | 17879 |
| 14 | Locked | 37.6 | 2884 | 18297 |
| 15 | Locked | 37.6 | 2949 | 18701 |
| 16 | Locked | 37.6 | 2932 | 18544 |
| 17 | Locked | 37.6 | 2985 | 18011 |
| 18 | Locked | 37.6 | 3049 | 18464 |
| 19 | Locked | 37.3 | 2913 | 19024 |
| 20 | Locked | 37.6 | 2911 | 19482 |
| 21 | Locked | 37.6 | 2915 | 20867 |
| 22 | Locked | 37.6 | 3015 | 19803 |
| 23 | Locked | 37.6 | 3139 | 19974 |
| 24 | Locked | 38.6 | 3209 | 20139 |
As you can see I am getting a lot of errors.
I've proved to myself that my equipment is all working correctly and that the Hub 3 is going offline.
How can I go about getting this fixed?
