nmcculloch's avatar
nmcculloch
17 hours ago
Errors shown on hub5
having problems today with network being slow / dropping out. The log file contains the following.
Do i have a problem? Do I need an engineer call out?
Nick
05-11-2025 20:53:44noticeGUI Login Status - Login Success from LAN interface
05-11-2025 20:15:57warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=[REMOVED]
05-11-2025 20:15:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=[REMOVED]
05-11-2025 20:15:53noticeREGISTRATION COMPLETE - Waiting for Operational status
05-11-2025 20:15:46warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=[REMOVED]
05-11-2025 20:15:46warningDynamic Range Window violation
05-11-2025 20:15:46warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=[REMOVED]
05-11-2025 20:15:41noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=[REMOVED]
05-11-2025 20:15:37noticeTLV-11 - unrecognized OID;CM-MAC=[REMOVED]
05-11-2025 20:15:35warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=[REMOVED]
05-11-2025 20:15:33noticeHonoring MDD; IP provisioning mode = IPv4
05-11-2025 20:15:22criticalNo Ranging Response received - T3 time-out;CM-MAC=[REMOVED]
05-11-2025 20:15:16criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=[REMOVED]
05-11-2025 20:15:14criticalCable Modem Reboot because of - HW or Power-On Reset
05-11-2025 17:50:59criticalNo Ranging Response received - T3 time-out;CM-MAC=[REMOVED]
05-11-2025 17:50:53criticalCable Modem Reboot because of - Reboot Timezone Change
05-11-2025 17:50:53criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=[REMOVED]
05-11-2025 17:48:15criticalNo Ranging Response received - T3 time-out;CM-MAC=[REMOVED]
05-11-2025 17:48:11criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=[REMOVED]
05-11-2025 17:48:09criticalCable Modem Reboot because of - HW or Power-On Reset
14-10-2025 10:42:29criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=[REMOVED]
14-10-2025 10:42:04criticalNo Ranging Response received - T3 time-out;CM-MAC=[REMOVED]
14-10-2025 10:41:59criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
14-10-2025 10:41:16criticalNo Ranging Response received - T3 time-out;CM-MAC=[REMOVED]
13-10-2025 09:53:09criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
12-10-2025 01:17:37criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
10-10-2025 03:11:25criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=20:[REMOVED]
08-10-2025 04:44:34criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
07-10-2025 14:52:35criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
05-10-2025 16:46:03criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
04-10-2025 13:44:00criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
02-10-2025 08:41:28criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=20:[REMOVED]
27-09-2025 16:43:18criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REMOVED]
1 Reply
    More informative data is found in the Downstream and Upstream tabs of the Hub.
