AlysonWW's avatar
AlysonWW
11 months ago
Disney+ Not Working
Hey
I switched to Virgin broadband last week and for the last 3 days I’m not able to access DisneyPlus. I have tried my laptop, phone, fire stick and sky box and it won’t work on any of them when I’m connected to Virgin.
If I hotspot and use my mobile data it works so it is definitely a Virgin issue. I have tried resetting the app, clearing cache etc but no luck. Does anyone have a fix for this?
  • Hello AlysonWW,
    Welcome to the Community and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re having with Disney + at the moment.
    Are you getting any error message, when trying to access Disney + on your devices? Please could you try to reset your hub and let us know if that makes any difference unless you've tried that already.
    Kind Regards,
    Steven_L
  • Col_H's avatar
    Col_H
    Hey AlysonWW,
    We're having the exact same issue here:
    Disney+ app not able to connect again | Virgin Media Community - 5634668
    Second time it's happened to us since moving house last year though last time it fixed itself eventually. Never had this at the old house and have been a Virgin customer since they were Telewest so I can assure you it's not a normal thing with Virgin.
    I don't have any solutions at the moment but you could try going to https://whatismyipaddress.com/ to double check your IP is showing as being from the right country and not being forwarded anywhere by a VPN or anything else.
