sefo1979's avatar
sefo1979
Disney + blocked on wifi
Hi I only have broadband with you no TV. We are unable to access Disney plus on any device using WiFi but it works fine on our mobile connections. I’ve reset the box etc to no effect. Can you sort this out please
  • Hi, I am also having this issue. Disney has not been working for a month now on home WiFi but works on mobile data. Disney + support have tried all their troubleshooting steps which haven't worked and I've restarted the modem a million times. Any advise would be great.
    • Kath_P's avatar
      Kath_P
      Hi Daniel_H96,
      Thanks for coming back here.
      I've just replied to your thread here: Disney + not working on WiFi
      Please make sure you are only posting once about your issue. If you need to update the thread then just reply to your original thread rather than creating a new one. We understand it's frustrating when something's not right however posting more than once about the same fault makes the boards look busier than what they actually are. It also means we could take longer to reply due to needing to sift through duplicate posts.
      Have a look at my reply on the other thread and stick with that one so we keep all the information in one place.
    Streaming TV services can be blocked by having Parental Controls enabled.
    • Robert_P's avatar
      Robert_P
      Hello sefo1979
      We're sorry to hear of the Disney+ issues experienced over your wireless network, we can understand the confusion and frustration this is causing and appreciate you letting us know via the forums.
      We can see you have spoken to the team since posting, we trust they were able to offer a resolution or support in regards to this issue?
      Let us know if you need further assistance with this and we'll be happy to help.
      • RQS's avatar
        RQS
        I’m having the exact same problem. The app is not working in my devices when using VM WiFi but is doing so when I use my mobile data. Therefore it’s not the app that is the problem. I don’t use a VPN either.
    Hi sefo1979
    If you are unable to connect to Disney+ using VM broadband then it may be due to a VPN which doesn't use your actual VM internet address..
    Are you using a VPN?  Some are used by anti virus programs and others can be browser extensions.
    Go to https://whatismyipaddress.com/ and check that the IPv4 address matches the one showing in your VM hub under Admin > Info > WAN IP Settings > IPv4 address.
