Matt1489's avatar
Matt1489
Damaged fibre cable
We were told by the VM installation engineer that the cable to the house was showing a measurement of -30 (not sure what units). He said he had booked in for the cable to be replaced, but it took 3 months to be installed the first time. We now have no Broadband at all and the hub is showing a slow pulsing white light, which other posts suggest is due to the faulty cable, what should we do? We were given a dongle whilst we waited for the first installation but O2 has really poor signal in out area, so it doesn't really work.
    You will need to ring if you are looking a fast resolution.  The VM Mods on this Community Forum can take several days to respond.
  • Hi Matt1489 👋🏼.
    Thank you for posting, welcoming you onto our community forum 😊.
    Sorry to see you are having issues with your cable and have no connection ☹.
    I can have a look for you, I will have to investigate 🧐.
    I will have to private message you.
    Please watch out for the envelope ✉.
