SRC0N's avatar
SRC0N
DAMAGED CABLE
DAMAGED CABLE ON VICARAGE ROAD WOLVERHAMPTON WV2 1DT
CANT LOCATE AN EMERGANCY CONTACT NUMBER TO INFORM
  • jbrennand's avatar
    Is this affecting your (or other's) connection?
    Check in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    If so but not in those two places -  report it in the usual way on 150 (VM line)  or 0345 454 1111 others (national rate). See what they say when they test your connection.
  • goslow's avatar
    goslow
    Are you reporting because it is you/your organisation that has damaged the cable?
  • Zoie_P's avatar
    Zoie_P
    Hi SRC0N
    Thank you for your post and for letting us know, we will need some more info on where this happened. I will pop you over a PM, and we can go from there. Keep an eye out for the little envelope 👀📩
    Zoie
  • it is fine, i got through to a customer service help on whatsapp and they ensured the correct team will be sent to site to rectify - would highly recommend an emergency works number as it took me 2 hours to report a damaged cable..
    others would have just left it !
