Ash_101's avatar
Ash_101
9 months ago
Constant T3/T4 Timeouts and Disconnects – Virgin Hub 6
Hi all,
I'm hoping someone can help me or point me in the right direction.
For the past few weeks, I've been experiencing frequent disconnections on my Virgin Media broadband using a Hub 6.
Initially it was happening twice a day (for over 8 months now), but in the last weeks it has escalated to disconnecting every few minutes.
What I've Done So Far:
Rebooted the hub multiple times, replaced the coaxial cable from wall to modem, confirmed all connections are tight and corrosion-free, my Hub been replaced by the ISP after talking with support.
Had a technician that told me he need to open a call to the network team but the support didn't find such call, they set me a new technician to arrive but the only time for visit is two weeks and i'm working from home 100% and cant work atm :(
no other ISP offer service in my area in Dublin...
Is there anything i can do? as far as i can tell the issue is noise on the line, but support wont let me talk with anyone in the network team.
Thanks!
Modem Log Errors - These are recurring in the logs:
T3 timeouts: "No Ranging Response received",  T4 timeouts: "No Unicast Maintenance opportunities received", "Received Response to Broadcast Maintenance Request, but no Unicast Maintenance opportunities", "ToD request sent – No response"
The logs flood with these events during and before disconnections.
DOCSIS 3.0 Downstream Channels:
| Ch | Freq (Hz)   | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
|  1 | 482000000   | 4.8          | 40       | QAM 256    | 13         |
|  2 | 174000000   | 4.4          | 40       | QAM 256    | 1          |
|  3 | 182000000   | 4.4          | 40       | QAM 256    | 2          |
|  4 | 190000000   | 4.4          | 40       | QAM 256    | 3          |
|  5 | 198000000   | 4.4          | 39       | QAM 256    | 4          |
|  6 | 206000000   | 4.6          | 38       | QAM 256    | 5          |
|  7 | 214000000   | 4.4          | 39       | QAM 256    | 6          |
|  8 | 222000000   | 4.7          | 39       | QAM 256    | 7          |
|  9 | 230000000   | 4.3          | 39       | QAM 256    | 8          |
| 10 | 238000000   | 4.1          | 39       | QAM 256    | 9          |
| 11 | 251000000   | 3.3          | 39       | QAM 256    | 10         |
| 12 | 259000000   | 3.6          | 40       | QAM 256    | 11         |
| 13 | 474000000   | 4.6          | 39       | QAM 256    | 12         |
| 14 | 490000000   | 4.9          | 40       | QAM 256    | 14         |
| 15 | 498000000   | 5.0          | 40       | QAM 256    | 15         |
| 16 | 506000000   | 5.0          | 40       | QAM 256    | 16         |
| 17 | 514000000   | 5.0          | 39       | QAM 256    | 17         |
| 18 | 522000000   | 5.0          | 38       | QAM 256    | 18         |
| 19 | 530000000   | 5.1          | 38       | QAM 256    | 19         |
| 20 | 538000000   | 4.9          | 39       | QAM 256    | 20         |
| 21 | 546000000   | 4.8          | 40       | QAM 256    | 21         |
| 22 | 554000000   | 5.0          | 40       | QAM 256    | 22         |
| 23 | 714000000   | 4.9          | 40       | QAM 256    | 23         |
| 24 | 722000000   | 4.7          | 41       | QAM 256    | 24         |
| 25 | 730000000   | 4.8          | 41       | QAM 256    | 25         |
| 26 | 738000000   | 5.0          | 41       | QAM 256    | 26         |
| 27 | 746000000   | 5.0          | 41       | QAM 256    | 27         |
| 28 | 754000000   | 5.2          | 40       | QAM 256    | 28         |
| 29 | 762000000   | 5.2          | 40       | QAM 256    | 29         |
| 30 | 770000000   | 5.2          | 40       | QAM 256    | 30         |
| 31 | 778000000   | 5.2          | 40       | QAM 256    | 31         |
| 32 | 786000000   | 5.1          | 40       | QAM 256    | 32         |
Channel Lock Status & Errors:
| Ch | Lock   | RxMER (dB) | Pre RS Errors | Post RS Errors |
|  1 | Locked | 40         | 1              | 0               |
|  2 | Locked | 40         | 0              | 0               |
|  3 | Locked | 40         | 0              | 0               |
|  4 | Locked | 40         | 0              | 0               |
|  5 | Locked | 39         | 0              | 0               |
|  6 | Locked | 38         | 0              | 0               |
|  7 | Locked | 39         | 0              | 0               |
|  8 | Locked | 39         | 0              | 0               |
|  9 | Locked | 39         | 0              | 0               |
| 10 | Locked | 39         | 0              | 0               |
| 11 | Locked | 39         | 0              | 0               |
| 12 | Locked | 40         | 0              | 0               |
| 13 | Locked | 39         | 2              | 0               |
| 14 | Locked | 40         | 4              | 0               |
| 15 | Locked | 40         | 3              | 0               |
| 16 | Locked | 40         | 3              | 0               |
| 17 | Locked | 39         | 5              | 0               |
| 18 | Locked | 38         | 0              | 0               |
| 19 | Locked | 38         | 3              | 0               |
| 20 | Locked | 39         | 2              | 0               |
| 21 | Locked | 40         | 0              | 0               |
| 22 | Locked | 40         | 3              | 0               |
| 23 | Locked | 40         | 0              | 0               |
| 24 | Locked | 41         | 0              | 0               |
| 25 | Locked | 41         | 0              | 0               |
| 26 | Locked | 41         | 0              | 0               |
| 27 | Locked | 41         | 0              | 0               |
| 28 | Locked | 40         | 2              | 0               |
| 29 | Locked | 40         | 3              | 0               |
| 30 | Locked | 40         | 1              | 0               |
| 31 | Locked | 40         | 0              | 0               |
| 32 | Locked | 40         | 0              | 0               |
DOCSIS 3.1 (OFDM) Channel
| Ch | Width (MHz) | FFT | Subcarriers | Modulation   | First Subcarrier (Hz) |
| 33 | 64          | 4K  | 1247        | QAM 4096     | 1408                   |
| Ch | Locked | RxMER (dB) | PLC Power (dBmV) | Corrected Errors | Uncorrectables |
| 33 | Yes    | 39         | 3.7              | 9218211          | 0              |
DOCSIS 3.0 Upstream Channels
| Ch | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
|  0 | 39400000       | 37.0         | 5120                | QAM 64     | 3          |
|  1 | 46000000       | 37.5         | 5120                | QAM 64     | 4          |
Upstream Channel Timeouts
| Ch | Type  | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
|  0 | ATDMA | 0           | 0           | 17          | 0           |
|  1 | ATDMA | 0           | 0           | 25          | 0           |
  • jpeg1's avatar
    jpeg1
    Difficult for anyone here to offer advice as this is the UK forum and we don't use the Hub 6.  There isn't much noise showing on your figures, but that would be normal shortly after a reset. Too many T2s though. What does it look like after a few days?
  • Since i didn't managed to get any help from the tech support here i hopes the forums (even if UK) could help me confirm that this is network issue on the ISP side...
    After few days upstream T3 and T4 timeouts are in the dozens or even hundreds, dozens downstream 3.0 post RS errors and the downstream 3.1 have hundreds of millions corrected errors.
  • jpeg1's avatar
    jpeg1
    I don't blame you for reaching out, it sounds like your tech support is no better than ours.
    A Hub exchange sounds like a good first step, if you can get one, but this does sound like an external network issue. Have you checked whether your neighbours have similar problems?
  • Support already sent me a new hub, but unfortunately, it didn’t resolve the issue. I also know for certain that one of my neighbors is experiencing similar problems — I’ve seen a technician at their property several times recently.
    My best guess is that this is due to upstream noise or interference at the cabinet, node, or CMTS. It’s been a while since I last worked with broadband infrastructure, so I was hoping someone here might have a tip or insight I’ve overlooked.
    Looks like it’s time to call support again... :)
    • Matthew_ML's avatar
      Matthew_ML
      Hey Ash_101, thank you for reaching out and a warm welcome to the community, we are sorry to hear you are having some connections.
      Can we just confirm sorry, are you based in Dublin?
      • Ash_101's avatar
        Ash_101
        Hey, sorry for the late reply!
        Yes, I’m based in Dublin. After a few more tries with the support team, I finally have a technician visit scheduled, along with a call with the network engineers while the technician is here—happening today. Hopefully this will finally solve the issue!
  • jpeg1's avatar
    jpeg1
    I'd certainly agree that this is an upstream problem.
