Akaossin's avatar
Akaossin
5 months ago
Constant problems, zero solutions.
So I've had intermittent problems over time. RCS Partial Service, Sync Timing, No Ranging Response.
I know this is a problem with the box outside. How do I know? They've replaced the hub, the cabling in and out of my home, and rebooted everything so many times I just say I have at this point.
The issue isn't my hub, it isn't the connections, it isn't the damn wifi as it's hard wired, it isn't the devices, it's outside. The box.
Can someone tell me exactly how to get this issue raised to the right people, who will actually fix it, and not have to sit through 10-20 minutes of the most boring, mundane copy/paste directions and days waiting for another engineer to change nothing?
    Akaossin wrote:
    This is after they "sent a signal to boost strength"
    The DS power (signal) is already at the top of the spec.  However, the PostRS errors are the thing to focus on.  Unless these are at zero or close to, it suggests noise on the circuit.  If the internal wiring is okay, then we can assume the problem is outside.  It could even be anther user on the same street cabinet with dodgy wiring?
      This is dead thread that is 2 months old.
      Create a new thread, an be quite specific about your problems.
  • Akaossin's avatar
    Akaossin
    Now 7 visits in, they've escalated to an area manager and they replaced my hub. Issue still persists.
    How long do I need to wait with this before I can bail out of the contract with no cost? I really don't think anyone is doing anything to fix it anymore.
    2 visits just looks around run a "test" which was a speed test (which isn't needed as the speed, when connected, is always the best it can be).
    Any time I try to talk to customer service, I get a wifi or reboot walkthrough that I DO NOT NEED.
    It's getting tiring and expensive having to wait in for yet another visit that solves nothing.
  • To get the issue escalated you'll need to submit a complaint through the complaint process.
    Here's the page (scroll down to find the form): https://www.virginmedia.com/help/complaints
    When you write your complaint, take a screenshot because they won't send you a copy.
    The purpose of "technical support" is to delay you from opening a complaint. The only thing that motivates Virgin Media is a complaint. Once you open the complaint, the 2 month countdown starts, and at the end of that countdown you can escalate to the Communications Ombudsman (Which is a misleading name for an outsourced complaints-handling company that several ISPs pay to handle complaints, it's not impartial, they're paid by Virgin Media, and they will be biased in favour of Virgin Media).
    You need to gather lots of evidence to prove that you're not getting the speeds you're paying for, and that you can't use the internet.
    Set up a BQM: https://www.thinkbroadband.com/my-profile/broadband-quality-monitor
    Take speed tests every day, and record it all in one big document (with dates and  times noted along with the screenshots).
    The important thing here is every time they call you or email you, you need to say firmly "do not close the complaint, the issue is not resolved". You will find that your internet might work fine for a while, but do not let them close the complaint. Hold the complaint open until it gets to the ombudsman, regardless of what they do or say.
    Hope this helps.
  • Akaossin's avatar
    Akaossin
    15070000001037256 qam13
    25150000001037256 qam14
    35230000001037256 qam15
    45310000009.537256 qam16
    55390000009.537256 qam17
    65470000009.637256 qam18
    75550000009.537256 qam19
    85630000009.437256 qam20
    9571000000937256 qam21
    105790000008.537256 qam22
    11587000000836256 qam23
    125950000008.337256 qam24
    13603000000836256 qam25
    146110000007.837256 qam26
    15619000000737256 qam27
    166270000007.336256 qam28
    17635000000736256 qam29
    18643000000736256 qam30
    196510000006.536256 qam31
    206590000006.536256 qam32
    21667000000636256 qam33
    22675000000636256 qam34
    236830000005.636256 qam35
    24691000000536256 qam36
    1Locked37.34728586957
    2Locked37.35756183300
    3Locked37.64164876709
    4Locked37.34386973303
    5Locked37.33452864611
    6Locked37.33168059311
    7Locked37.33312746488
    8Locked37.62609849391
    9Locked37.64035762226
    10Locked37.32628247371
    11Locked36.64678857871
    12Locked37.32416752416
    13Locked36.64830250257
    14Locked37.31965948192
    15Locked37.64889454469
    16Locked36.62551049863
    17Locked36.35279152511
    18Locked36.62924147035
    19Locked36.35182655188
    20Locked36.33619555501
    21Locked36.65582548394
    22Locked36.35228457521
    23Locked36.64720555758
    24Locked36.65425052029
    ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
    14959996643.3512064 qam1
    23659997541.8512064 qam3
    33010000041.5512064 qam4
    44309999842.5512064 qam2
    52359985941512064 qam5
    ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
    1ATDMA0050
    2ATDMA0040
    3ATDMA0010
    4ATDMA0000
    5ATDMA0010
    TimePriorityDescription
    15/07/2025 01:47:4criticalNo Ranging Response received - T3 time-out;CM-MAC=*;
    14/07/2025 12:34:2Warning!RCS Partial Service;CM-MAC=*;
    14/07/2025 12:34:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:33:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:33:51Warning!RCS Partial Service;CM-MAC=*;
    14/07/2025 12:33:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:33:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:33:26Warning!RCS Partial Service;CM-MAC=*;
    14/07/2025 12:27:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:27:44Warning!RCS Partial Service;CM-MAC=*;
    14/07/2025 12:21:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    14/07/2025 12:21:30Warning!RCS Partial Service;CM-MAC=*;
    14/07/2025 12:18:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    13/07/2025 19:28:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=*;
    13/07/2025 19:01:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    13/07/2025 13:03:44Warning!RCS Partial Service;CM-MAC=*;
    13/07/2025 13:03:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=*;
    13/07/2025 12:28:4Warning!RCS Partial Service;CM-MAC=*;
    Mac addresses removed for obvious reasons.
