Jems90's avatar
Jems90
Just joined
10 months ago
Connection dropouts - T4 timeouts and high Post RS errors
Getting fed up with the connection dropping out several times a day - used to be once a week which whilst annoying I can live with but it's increased recently.
When it goes down I'll get this in the logs:
27-05-2025 11:05:35    critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=d8:33:b7:53:7f:7b;CMTS-MAC=00:01:5c:7a:a4:d2;CM-QOS=1.1;CM-ER=3.1;
27-05-2025 10:46:58    critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=d8:33:b7:53:7f:7b;CMTS-MAC=00:01:5c:7a:a4:d2;CM-QOS=1.1;CM-VER=3.1;
Post RS errors look high - can anyone sense check these and see if I need to try and get something fixed:
3.0 Downstream channels
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    162000000    0.3    38    QAM 256    4
2    138000000    1.2    39    QAM 256    1
3    146000000    0.6    38    QAM 256    2
4    154000000    0.1    38    QAM 256    3
5    170000000    0.7    38    QAM 256    5
6    178000000    -1.2    38    QAM 256    6
7    186000000    -1.6    38    QAM 256    7
8    194000000    -2    38    QAM 256    8
9    202000000    -2.5    38    QAM 256    9
10    282000000    -2.5    39    QAM 256    19
11    290000000    -2.3    39    QAM 256    20
12    298000000    -2    39    QAM 256    21
13    306000000    -1.7    40    QAM 256    22
14    314000000    -1.5    40    QAM 256    23
15    322000000    -1.6    40    QAM 256    24
16    330000000    -1.7    40    QAM 256    25
17    338000000    -2.2    40    QAM 256    26
18    346000000    -2.7    39    QAM 256    27
19    354000000    -3.1    39    QAM 256    28
20    362000000    -3.1    39    QAM 256    29
21    370000000    -3.1    39    QAM 256    30
22    378000000    -3    40    QAM 256    31
23    386000000    -2.9    40    QAM 256    32
24    394000000    -2.8    40    QAM 256    33
25    402000000    -3    39    QAM 256    34
26    410000000    -3.2    40    QAM 256    35
27    418000000    -3.3    40    QAM 256    36
28    522000000    -3.8    40    QAM 256    37
29    530000000    -3.8    40    QAM 256    38
30    538000000    -3.8    40    QAM 256    39
31    546000000    -3.5    40    QAM 256    40
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    38    11489677    8278084
2    Locked    39    7815311    3804222
3    Locked    38    21056963    7750970
4    Locked    38    17571453    14996225
5    Locked    38    158666006    18484018
6    Locked    38    91968527    91545124
7    Locked    38    159360987    4857291
8    Locked    38    434    0
9    Locked    38    179    0
10    Locked    39    364    46
11    Locked    39    463    60
12    Locked    39    828    81
13    Locked    40    743    121
14    Locked    40    690    149
15    Locked    40    642    89
16    Locked    40    418    13
17    Locked    40    565    95
18    Locked    39    645    101
19    Locked    39    655    86
20    Locked    39    686    151
21    Locked    39    703    147
22    Locked    40    578    30
23    Locked    40    143    0
24    Locked    40    150    0
25    Locked    39    451    0
26    Locked    40    670    44
27    Locked    40    517    5
28    Locked    40    401    4
29    Locked    40    643    17
30    Locked    40    721    74
31    Locked    40    700    107
3.1 Downstream channels
Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
41    190    4K    3736    QAM 4096    148
Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
41    Locked    38    -5.2    2017698270    681318
3.0 Upstream channels
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
0    49600000    46.8    5120    QAM 64    5
1    43100000    46.3    5120    QAM 64    6
2    36600000    46    5120    QAM 64    7
3    30100000    46    5120    QAM 64    8
4    23600000    45.5    5120    QAM 64    11
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
0    ATDMA    0    11    0    0
1    ATDMA    0    11    0    0
2    ATDMA    0    11    0    1
3    ATDMA    0    11    0    1
4    ATDMA    0    11    0    0
3.1 Upstream channels
Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
12    10.4    42.7    2K    QAM 256
Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
12    OFDMA    208    74000000    0    3
    Yes, there is noise on the line as shown by the PostRS errors.
    Try checking with Area faults on  0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
    Otherwise wait here a day or two for a VM Mod to pick this up and discuss.
  • Alex_RM's avatar
    Alex_RM
    Hi Jems90,
    Thanks for posting and welcome to our community 😊
    Sorry to see you're having some connection issues, how're things since you posted? Are there any problems showing online here ?
    Alex_RM
