lpl's avatar
lpl
Cannot connect to Signal when using Virgin Media
Since 16 Apr, I am not able to connect to Signal (Messenger) whenver connect to Virgin Media broadband wifi. I have iPhone and Android mobile tested. Both are not working when connecting with wifi. It works immediately if we switch off the wifi and switch to 4G.
I have a LinkSys wifi router. As a test, we setup 8.8.8.8 as DNS but still the same.
I have turned off child and virus protection in Virgin Media setting but still not helping.
Why Virgin is blocking Signal?
1 Reply
  • Ilyas_Y's avatar
    Ilyas_Y
    Hey lpl Thanks for reaching out to us on the Virgin Media forums. 👋🏼
    I'm sorry to hear about the issues with the signal on the Virgin Media hub.
    Can I ask that you try with the Virgin Media router only and see if the signal works there?
    Let us know and we can assist from there. 🧾
    Kind regards,
    Ilyas.
