Wimc99's avatar
Wimc99
c10% packet loss, Virgin Hub 3
Hello,
Been on Virgin since Jan, and have noticed lots of errors (mainly in online games), ran a set of tests and found I am experiencing roughly 10% packet loss when pinging google, and my ping is between 10-60.
i have 300mb internet, with a Virgin hub 3. The Hub 3 is connected to a deco unit in AP mode.
1. checking the router stats, my downstream power is 10.5-11.7 for most channels, this is outside the threshold, could this be an issue?
2. Is it worth trying the hub 3 in modem mode, and using the deco as the router?
any other suggestions welcome
    • Wimc99's avatar
      Wimc99
      Hi - SS below, interestingly on Samknows it shows as OK, but on WinMTR (which is what I usually use) it shows 9% (It's actually up to 12% now)
    Assuming google.com works perfectly well in a web browser, what is WinMTR telling us ?
    • Wimc99's avatar
      Wimc99
      Yeah it works fine - interestingly tried a few IP’s and it’s a mixed bag.
      Have setup a set of Deco’s and put the H3 into modem mode and now WinMTR detects no issues (the link you sent won’t work with deco)
      • John_GS's avatar
        John_GS
        Hi Wimc99
        Apologies for the internet issues.
        You do need a tech visit, this is because some of your downstream power levels are out of spec.
        I'll send you a PM now to book this in.
    Realspeed is a test that requires the VM Hubs to be in Router mode.
    For Modem mode + the Deco try this ( it works in all modes ) : https://speed.cloudflare.com/
    the result will be via the Hub + Deco + your device so results may vary especially if Wi-Fi is involved.
