mickb1960's avatar
mickb1960
13 days ago
Blink Camera's VM hub 4 and router option.
I've  frustratingly tried all of the suggested ways of connecting my Blink Camera's to my VM  Hub 4, the only one I've not tried is to buy a router and do it that way . Has anyone got any advice on weather this is a viable option and if so what type of router is best.
  • Is fitting my own router simple to attach to my VM Hub 4 and in order to get my blink cameras to work, which one would you advise please?
    • goslow's avatar
      goslow
      Tudor has provided instructions for attaching a router to the hub in modem mode, here
      https://community.virginmedia.com/discussions/Wireless/hub-in-modem-mode/5649088/replies/5649090
      It would be best to start your own thread, as this one is over 2 years old.  It is easy to set the Hub 4 in modem mode and use a 3rd party router btw.
    Usually these types of devices have a couple of valid methods at the most.
    I'd suggest get hold of the Blink Camera's manuals, follow the as new installation process to the letter.
  • legacy1's avatar
    Look for a better router one with wifi 6 1Gb ports or better
  • As any one successfully connected HUB 4 to their Blink Modual? I've tried of the recommended hub settings with no luck. Would it be easier to by my own 2.4 ghz hub and start afresh? I'd welcome any advice.
    • Matthew_ML's avatar
      Matthew_ML
      Hey mickb1960, thank you for reaching out and I am sorry to hear you are having some issues connecting to the blink module.
      Did any of the above advice here help at all?
      • mickb1960's avatar
        mickb1960
        Thanks to all those who responded and I have already tried most of their advice. I tried again today but sadly no luck. I am wondering if having a separate router attached to my VM Hub 4 would make any difference?
        Michael
    • dhairbus's avatar
      dhairbus
      Dialled in
      Connect Blink Module to Hub 4 (Not Hub 4 to module) It will only connect to 2.4 WiFi so make sure 2.4 GHz is enabled    My system has been working for over 8yrs with no issues.
      All connectivity is performed on the mobile device with the Blink app. All reference to home screen is the mobile device Blink app home screen.           https://support.blinkforhome.com/en_US/getting-started-with-sync-module-xr/sync-module-xr-setup
      Begin by plugging in your Sync Module.
      From the Home Screen , tap the + icon in the upper right corner.
      Tap Sync Module.
      Scan the QR code on the back of the device or tap Enter Serial Manually. Once the serial number is recognized, select an available system to add your Sync Module. If no systems are available or if none exist, create a new one with a unique name, then tap Continue. Learn more about creating and managing systems.
      Once the Sync Module displays a blinking blue and solid green LED, tap Discover Device. If a different light pattern is displayed, refer to Understanding the LEDs on your Sync Module.
      You will be prompted to join the temporary Wi-Fi network ‘BLINK-xxxx’ (where ‘xxxx’ is the last four digits of your Sync Module’s serial number). Tap Join / Connect.
      From the list of available Wi-Fi networks, select your local Wi-Fi network. Enter the Wi-Fi password and tap Join. If your network does not appear, tap Refresh List. After tapping Join, the Sync Module may perform a firmware update, which can take a few moments.
      Once the Sync Module has been successfully added to your system, a completion screen will appear. Tap Done.
      So many IoTs and CCTVs come with very poor quality config apps !
      Try disabling the VM Hub's 5GHz Wi-Fi during the set up of your Blink Camera,
      do this from the VM Hub 4 menu.
