colin99's avatar
colin99
11 months ago
Advice please on suitable Mesh system
I have a Volt Gig1 broadband connection, Hub 5 and 3 VM WIFI pods. My WIFI connected outside security cameras keep losing connection and I'm looking at putting in a Mesh network hoping this will solve the problem. Which manufacturer and model would you recommend?
Many thanks - Colin
  • A Hub 5 and 3 Wifi Pods is a Mesh System.
    It may be you need to relocate the Pods to give a better connection to the cameras?
    However some users here have had success with this unit TP-Link RE450 AC1750 Dual Band Wi-Fi running along side the VM Wifi for cameras.   Also the TP-Link DECO Mesh systems are also mentioned here as a solution.
    Another point to consider is using PoE cameras rather than Wifi.
  • legacy1's avatar
    send pods back get a router to the hub then mesh to it.
