BillBudd's avatar
BillBudd
Superfast
Samsung Universal TV Remote and TV 360
I have been offered the upgrade to TV 360, which I will initiate when I get back from holiday.  My TV is a Samsung which comes with a universal remote.  This currently works well controlling the TV and the TIVO box.
I've read the existing posts in the forum in relation to using the Samsung universal remote to control the TV 360, but there does not seem to be a definitive answer.
So if anyone out there has successfully used their Samsung remote and the TV 360, please could list the steps you used to set it up.
Any help gratefully received.
Kind Regards,
Bill
    Hi Bill,
    There's no guarantee the following will work but see < this post >  and the link contained in that post.
    Also It sometimes works with either Arris DCX960 or just DCX960, and also Pace DCR7111
    You could also try selecting satellite box > tv directly
    Then enter your postcode and select Virgin
    Select the HDMI port that your Virgin box is connected to and hit Channel Up and select NO around half a dozen times. After that it will offer you to search for model of your box manually.
    • Ang121's avatar
      Ang121
      Just joined
      I'm late changing my settings, but thank you, Pace DCR7111 worked for me too. I did however have to select Pace from the brand list then search "DCR" and DCR7111 was the first on the list. When I searched DCR7111 I didn't get any results. They don't make this easy do they!
    • Antgeee's avatar
      Antgeee
      Recently had the same issue. I have a Samsung TM2360E universal remote, and a Arris DCX960/KK0B/N215/1000 Virgin 360 box.
      The remote was working fine using the Pace DCR7111 setting, but stopped working 1/11/24. So i deleted and re added, fail. Started relooking at the Ariss options again. Worked.
      Select ARRIS
      Select Search More models
      Choose the ‘NEXT’ model at the bottom of the list (Yes the model called ‘NEXT’).
      All working again fine
