johnrance2002's avatar
johnrance2002
5 months ago
360 box not saving recordings ofter power cut and error code comes on
Hi all, had this problem for a while now even when I switch it off to do a reboot loses all recordings, also freezes picture and comes up with error code during playback,don't want a engineer as I will have to take time off work is there any way I could get the box replaced.
  • Thanks for reaching out to us johnrance2002, and a very warm welcome to you!
    Sorry to hear of the issues you've been experiencing with the set top box since a recent power cut.
    Are you please able to confirm what error code is being populated?
    With this, have you been issued with an error messages at all?
    It may be worth looking into the error code via this link, and see if any suggested basic troubleshooting will allow for the issue to be resolved.
    David_Bn
    • johnrance2002's avatar
      johnrance2002
      Hi, I've tried that still the same won't save any recordings after switching box off.
      • Vikki_M's avatar
        Vikki_M
        Okay thank you.
        Just to clarify for us please, what is the error message you see on screen?
        Please pop back to us when you can.
  • japitts's avatar
    japitts
    Tech visits are available on weekends as well as evenings.
  • Hi. The code was cs2217 but it doesn't come up for everything sometimes  it stops playing and says delete.
  • If powering off the box with either the switch on the back of the box or at the plug is deleting your recordings then the box is faulty and needs replacing.
    Virgin don't often just send out replacement boxes just in case it's not the box that's faulty or there are any other issues. It also allows the box to get back into the repair loop sooner.
    As japitts said you can get a weekend appointment (Saturday).
